Hi fcwilt
I just set up a second Object Library2, in AppData, and it works fine.
There were several steps.
Anton mentions possibility, but the details are sketchy:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8824.16
1. Copy 70 ObjLibrary.js, to 71 ObjLibrary2.js, in the AppData startup folder. (My folder is called MoIAppData)
Edit 71 ObjLibrary2.js by: (for example):
renaming title line to "ObjLibrary2".
renaming menu line to "ObjLibrary2".
2. In the AppData customUI folder, by copy, rename, and edit, make ObjLibrary2.cfg, containing "Object Library;MOI\objects2".
also make ObjLibrary2.menu and edit the file in 4 places to "ObjLibrary2".
(Separate copies were made, rather than editing the original two files.)
3. Create objects2 folder in the AppData\Roaming folder, next to existing objects folder.
Admin. Priv. not needed for AppData, AFAIK, but may be needed for other locations?
(Windows10, MoI4Beta) (So MoI3 method would be a bit different?)
