Hi BlackBird, can you please post the STEP file so I can test the original import process?
It looks like one problematic surface is a sphere with trims that happen to go right through the "pole" area of the sphere. Those pole areas are spots where the surface is collapsed down to a single point and can sometimes be difficult to process well because of things like degenerate derivative values.
The other problem one is a closed surface, that can also be a sensitive area to process because some CAD programs make trim boundaries that cross over the "seam" edge of the closed surface so the import has to try and split edges where they cross the seam.
For the larger one, the actual error seems to be in the display engine only, if you do an export to a polygon mesh format like .obj for example that error is not displayed there. So I think you can ignore that one.
The other surface needs to be untrimmed and retrimmed to repair it, I have attached a 3DM file here where I've done that.
> I also couldn't copy and paste the geometry from Rhino to moi. It didn't happen anything.
What version of Rhino are you using?
