I can't add Model to object library
9973.1
Hi guys, Do you know why I can't add Model to object library. it was working before just fine not sure why now not working i am using Moi 3 on windows 10 check the attach video. thank you
9973.2 In reply to 9973.1
Hi albehany, by default Windows will prevent programs from modifying files inside the Program Files directories as a security measure. That's probably what is happening here.
If you go to the shortcut that you use to launch MoI, right click on it and choose "Properties" and on the "Compatibility" tab, turn on the checkbox that says "Run this program as an administrator". That will run MoI with an elevated privilege level that will then allow it to make modifications to directories inside Program Files which is where the object library stores its files for v3.
The v4 version stores it inside the appdata directory instead so that isn't needed for v4 I don't think.
Message 9973.3 deleted 6 Oct 2020 by BEMFARMER
Message 9973.4 deleted 6 Oct 2020 by BEMFARMER
9973.5
Thank you Michael, work for me.
9973.6 In reply to 9973.2
Sorry to but in here but the question caught my eye.
What "object library" is being talked about? It sound's like it might be something that I could use.
Thanks.
Frederick
9973.7 In reply to 9973.6
Hi Frederick, it's part of Max Smirnov's CustomUI mod here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
9973.8 In reply to 9973.7
Thanks for the info.
I located the BETA version for use with MOI v4 and installed it.
First impression: really grand!
Frederick
EDITED: 12 Oct 2020 by FCWILT
