Hi Matadem, the .stl file format does not have any method in it to label the unit system that its coordinates are in. So when you switched to a different unit system, the slicer software does not have any way to automatically know that the coordinates were now in cm instead of mm and just interpreted them as mm.
Check in your slicer software if there is an option you can set to tell it the unit system for the .stl file. If there is not an option for that and it only expects to receive units in mm then you'll need to make sure to export out in mm from MoI.
In MoI v4 there is a new option under Options > Import/Export > STL options > "Export units conversion" which you can set which will rescale the output .stl file into a specific target unit system. If you set that then that might be more convenient since you would not have to switch your main unit system over to mm when you do the export:
