Copy-Instance
9965.1
I've been searching but I can't seem to find a thread for this.
Is there a way to instance copies so that changes in the original are applied to copies.
Tim
9965.2 In reply to 9965.1
Hi Tim, sorry no MoI doesn't have a full instancing mechanism in it as of yet.
It does have a history update mechanism so it is possible to generate a copy of an object using Transform > Copy and then select the copied result and enable history updates using Edit > History > "Enable update". Then editing the original object will also update the copy but it's somewhat limited for the kind of edits you can do. You can do something like adjust control points.
9965.3 In reply to 9965.2
Got it.
Thanks for the quick reply, as always.
Tim
It's automatic too when you make a "Mirror"
Changement on the original will be reflected on the mirrored ;)
