Different length
9962.1
With the body designed from three profiles and a guide line, one leg is longer than the guide line indicates.
Could you please tell me what I doing wrong?
Bodo-Lutz
9962.2 In reply to 9962.1
Hi Bodo-Lutz, I'm a little puzzled by the strange result but it seems to have something to do with these small line segments at the ends of the guide lines:
Try the attached version, here I removed those segments and stretched out the last control point of the next segments.
Also I noticed the 3 profiles were not closed curves, they have a slight gap here:
I closed those up by using Transform > Move on the upper point to move it down. I'll have to investigate the weird result, seems like a bug.
9962.3 In reply to 9962.2
thanks for your quick help.
Before I've experimented a lot. I tried to cut off the body overlength, but impossible.
Unfortunately I hadn't found the missing 0.016 mm line in profile.
However, it would have been displayed with a test using the planar function. Next time I will do this.
Bodo-Lutz
