Tap Modelling Suggestions
9961.1
Hey all,
Was looking for suggestions as to how to model this tap head (in yellow!) in MoI...I was thinking about shopping it off to SubD but there must be a rail trick I'm just not thinking of?
Merci!
- Rich
9961.2 In reply to 9961.1
Hi Rich,
here is one way.
Hope it helps.
Barry
Another proposition...
EDITED: 15 Jun 2022 by PHIRO
For me SubD is a possible idea, but I never know before testing the result.
So do, redo, re-redo, test, re-test, re-re-test...
Fillet method :)
9961.6 In reply to 9961.1
The Biconcave script is another possible helper.
- B
YES !
The Biconcave script is nice for this...
Good idea !
F.
9961.8
Amazing cheers all!
I kind of ended up running with more of a Barry-H approach (4 outer spheres, and a revolve curve running into the center...) but then went a bit mad with the workflow. Yes the thing with SubD is it's always a guessing job (for me at least.)
Went with:
MoI OBJ (which was fine, really) > Houdini VDB to Polygon conversion for reliable re-mesh > 3D Coat for smoothing, bit of slight 'organic' surface imperfection...
I'll have to check this biconcave script!
- Rich
