Nuding ist a very helpful comand to move an objects according to the grids snap values.
What would amazingly helpful, too, is to nudge any value increment using the arrow keys or other hotkeys.
This is what I mean.
Imagine you have selected a face of a cube and you want to extrude it. Instead of typing in
the distance or moving the mouse pointer, you use the arrow keys to extrude it to a positive value (up)
or a negative value (down).
So if you had set grid snap to 1mm each time you toggle the arrow key, the selected face will be extruded
by 1mm > 1,2,3, ...
Same for offset, inset, etc ..
Advantage : minimalistic workflow, visual control, exact working by using the grid snap values.
Does such a command / script exsit ?
