How to do that shape correctly
9933.1
How to sweep that profile to have it without errors?
What is best way to do that? Loft, sweep, rail revolve?
9933.2 In reply to 9933.1
Blend between two extruded "semi-circle" edges looks good, but is not precisely on the line.
Fillet?
9933.3 In reply to 9933.1
Hi mdesign, to get a sweep without errors the profile curve can't extend a distance further than the radius of curvature of the bend.
For your case here that means the length away from the rail can't be larger than about this much:
One possibility though is to do the sweep that folds over itself, then use Edit > Trim with the "Isocurve" option to cut out the messy section:
Then you can put in a Blend there:
9933.4 In reply to 9933.3
Brilliant. Thanks for help. So I needed to use that bad geometry to create a good one. Wise :)
