> Does it possible to have the last Extrude function method memorized for repeat it ?
> (so Set Dir, Set Path, To Point or Tappered)
Sorry, no it would not work to do that with the current design of the Extrude command.
Currently the way it works is when you start up you are in the "extrude straight to point or distance" mode. When you push "Set Path", that switches to a different mode but there isn't any way currently to go back to the starting mode.
So if it just jumped directly to "Set Path" mode because you used that last time, that would then effectively disable "extrude straight to point or distance" mode for the rest of that modeling session.
