Automating conversion of IGES files to OBJ files
All  1-10  11-13
987.11 In reply to 987.10
Hi Jeff, can you please post your modified script (or e-mail it to me at moi@moi3d.com).
If I can repeat your problem over here it would help me understand what might be going wrong.
987.12 In reply to 987.11
I have attached the scripts I am using.
What I did was exported numerous parts from ProE and I want to convert them through MoI. I tried exporting in one large file, but the filesize must be too large for MoI (or it takes way too long to convert/import).
Thanks for your help.
Jeff
987.13 In reply to 987.12
Hi Jeff - the convert script has a bug where it assumes the file extension was 3 characters, like filename.igs - it gets hosed when it runs into one of the files with the 4-letter extension like filename.iges .
I've attached an updated version of Convert.js which should fix this up.
Please let me know if you run into any other problems with the updated script.
Show messages: All  1-10  11-13
