Automating conversion of IGES files to OBJ files
All  1-9  10-13
987.10 In reply to 987.8
I am looking at trying to use the batchConvert script to convert igs models to obj. The convert script works on the first Convert call in the script, but does not convert any other models in the list. I have only modified the script enough to add the model that I want to convert. Are there any suggestions as to what the problem might be?
Thanks!
Jeff
987.11 In reply to 987.10
Hi Jeff, can you please post your modified script (or e-mail it to me at moi@moi3d.com).
If I can repeat your problem over here it would help me understand what might be going wrong.
987.12 In reply to 987.11
I have attached the scripts I am using.
What I did was exported numerous parts from ProE and I want to convert them through MoI. I tried exporting in one large file, but the filesize must be too large for MoI (or it takes way too long to convert/import).
Thanks for your help.
Jeff
987.13 In reply to 987.12
Hi Jeff - the convert script has a bug where it assumes the file extension was 3 characters, like filename.igs - it gets hosed when it runs into one of the files with the 4-letter extension like filename.iges .
I've attached an updated version of Convert.js which should fix this up.
Please let me know if you run into any other problems with the updated script.
Show messages: All  1-9  10-13
