Hi Pilou, exact NURBS circles and arcs are made up of quadrants like that which will get creased if you move their control points around. MoI tries to replace those with an automatically rebuilt curve on surfaces of revolution but your extruded arc is not detected as a surface of revolution and so doesn't get the automatic rebuilt points with out the corner points at the quadrants.
Try using Rebuild on the arc before you extrude it, or move one control point of the arc before extruding it so that you won't have the surface that has corner points in its interior anymore.
