Restore Custom Row Layout
9847.1
Hello. Before this beta release, I had installed a custom GUI. Most of the customization went into AppData\Roaming\Moi. However I can't now open the previous beta release and now I've lost some CSS or HTML that allowed 2 rows at the bottom. Can anyone tell me where I might find this and adjust so I don't have to constantly go from File Open etc. over to far right Options?
Thanks!
Jason
9847.2 In reply to 9847.1
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=6507.0
custom ui from max smirnov
version moi3 or moi4
http://moi.maxsm.net/
2 rows at the bottom ... don't know how it's possible ... will wait the right answer ;)
a floating palette with custom tools ... could be nice ...press spacebar and hop ;)
EDITED: 22 Jun 2020 by CORCHET
9847.3 In reply to 9847.2
yes you have also that for any palett!
By Dinos for make a floatting palette with anything inside! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=5993.1
(here for French users : https://moiscript.weebly.com/palette-de-scripts.html )
EDITED: 22 Jun 2020 by PILOU
or this one! ;)
So very useful when you have several monitors! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=9758.1
9847.5 In reply to 9847.4
thanks but it's ok for me .. i have all menus ( right ) under names and only one icon menu is opened
all scripts on a big page ok
the bottom menu has too large icons even in 1920 resolution all stuff does'nt appear ... as said 'co3Darts' ... but it's not very important
9847.6 In reply to 9847.5
Yes the "big page" is also my solution but i keep the right menus when i make some tutos! ;)
9847.7 In reply to 9847.1
Hi Jason, was this maybe the custom UI that you had installed? :
http://moi3d.com/forum/index.php?webtag=MOI&msg=9242.13
9847.8 In reply to 9847.7
Yes Michael, that is the custom UI I did install. Looking at the last page thread, it appears it's not updated yet for this beta release.
9847.9 In reply to 9847.1
Hi Jason, so instead of making 2 rows how about removing some of the buttons that you don't use so it doesn't overflow your available screen width?
How often do you use the "Log" button for example?
The buttons in CustomUI are generated by .js files in AppData\Roaming\Moi\startup. Make a sub-folder in there something like "bak" and move some of the .js files into that sub-folder so they will not be triggered and won't add in their buttons.
Some good candidates to remove are:
LogScroll.js
Nodeeditor.js if you don't use the node editor
Align Buttons.js which are already available in the side pane under Transform > Align
HideLock.js which is already available on the Edit tab on the side pane
ResetAll.js which is already available on the View tab of the side pane and also by right-click on the "Reset" button on the bottom of each viewport
CPlane.js which is already available on the side pane in the View tab
Image.js which is already available on the side pane under the View tab
Select Buttons.js which is already available on the side pane under Select
If you use any of those very frequently then go ahead and keep them but otherwise get rid of them so you don't overflow the command bar.
9847.10 In reply to 9847.9
Michael, that worked great as an easy solution. I use Align constantly so I ended up with this. Much appreciated.
Jason
