can export shortcut
983.1
i can transport shortcut key to another computer?
excellent moi is my preferite 3d modelling software
Alari Vincenzo
http://xoomer.alice.it/gfx/
yes : find the file .../application data/moi/moi.ini
and you will have the new short cut key saved for another computer :)
but you must also copy past the new scripts or commands that you had used if you want that all work on another computer ;)
983.3 In reply to 983.2
ha ok ...
%APPDATA%\Moi\
thanks
Alari Vincenzo
983.4 In reply to 983.3
Yup, you can just copy that file to your other computer to bring all your settings over.
You can either copy it to that same spot %APPDATA%\Moi\ , or you can also place the moi.ini file in the same directory as moi.exe, if it finds it there it will load it.
By default it puts it in that %APPDATA% dir because users who don't have admin rights can't write to files under \Program Files.
