import OBJ
9780.1
I was searching the forum for a way to import obj into MoI, and found some entries that mention it can be done in V4, but not really how to and what is needed. So I downloaded the beta, but obj is not in the list of import formats. does it need an extra plugin? where can I find a tut or user manual for V4?
wim
9780.2 In reply to 9780.1
For V4: Menu SubD / Create from File ;)
else more general http://moi.maxsm.net/files/scripts/ImportObj.v.1.5.2015.09.10.zip
else for only the wire http://moi3d.com/download/Obj23dmWireframe.zip
9780.3 In reply to 9780.1
Hi Wim, the new OBJ importer in v4 is not a general purpose importer that can read in any type of OBJ file, it is for converting OBJ files that are set up for sub-d smoothing.
So if you have a sub-d model you can use that to convert it to a smooth NURBS surface model in MoI.
If your OBJ file just contains regular polygon mesh objects and not ones set up for sub-d smoothing, that type of data is not good to import into MoI.
There isn't one yet, I'll be working on that once the last beta is finished.
9780.4
Ok Tnx Michael, my intention was to import a specific custom sized bolt thread which I have as stl only, and redraw it in MoI. but as I understand it (and just tested a few minutes ago) the original shape is lost and turned into subd smoothed geometry.
So I will have to screen dump it in Blender and import the image I guess.
wim
9780.5 In reply to 9780.4
You have also an STL importer so you must not loose the original shape... ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=9546.9
9780.6 In reply to 9780.5
tnx Pilou, I will try that one!
wim
9780.7 In reply to 9780.6
Not sure STL that will be paradisiac ;)
If i remember! :)
http://moiscript.weebly.com/r2d3.html
but try also the _importBj by Max Smirnov
maybe that can works no so bad for your piece!
9780.8 In reply to 9780.7
tried them both but gave same result...
our should I try this in 3.2?
9780.9
the obj import to subd:
Size: 149 KB, Downloaded: 97 times, Dimensions: 529x759px
9780.10 In reply to 9780.9
Yes try in the V3 because it's an old one ;)
About the obj with _importObj what is the result?
http://moiscript.weebly.com/_importobj.html
EDITED: 26 Apr 2020 by PILOU
9780.11 In reply to 9780.10
wow, that one totally works! (I overlooked it in the comment above, my bad...
thanks Pilou!
w
9780.12 In reply to 9780.11
Yep so seems maybe you will have a better result in "Quadriangulate" with some third party first before importation! ;)
Maybe this free one! ;)
https://github.com/wjakob/instant-meshes
9780.13 In reply to 9780.11
The STL import one only supports ascii type STL files, not binary ones.
