Hi SADOOO, there is a list of all command names written down in the "Shortcuts" section of the help file here:
http://moi3d.com/3.0/docs/moi_command_reference11.htm#shortcutkeys
For installing CustomUI onto v3/windows 10, get the file CustomUI.1.03.win.mac.zip which is attached to the message at:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
Unzip the file and you should see that it contains 3 folders in it: "objects", "snapshots", and "ui". These need to be copied into the install folder.
The install folder for v3 is: C:\Program Files (x86)\MoI 3.0 .
So copy the "objects" folder from the .zip over to C:\Program Files (x86)\MoI 3.0 .
Also copy the "snapshots" folder from the .zip over to C:\Program Files (x86)\MoI 3.0 .
You should now have folders:
C:\Program Files (x86)\MoI 3.0\objects
and
C:\Program Files (x86)\MoI 3.0\snapshots
Now there is one more folder left to copy, the "ui" folder. For this one note that there is an already existing folder in the install with that name. So copy the contents of the .zip's ui folder into C:\Program Files (x86)\MoI 3.0\ui . It will ask you if you want to overwrite one file, say yes. Now it is installed.
