SELECT BOUNDARY
9746.1
Hi all is there a command in MOI similair to RHINO SELECT BOUNDARY where a closed curve is used to select anything contained within it?
thanks
Alex.
9746.2 In reply to 9746.1
Hi Alex, there isn't any built in method for that currently. There is a plug-in here which works for selecting solids that are intersected or contained by a closed curve though:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8088.5
9746.3
Hi Michael - thanks for that thought i had seen it pop up before - I cant get it work with V4 - I have the curve preselected and then run the script but nothing happens.
thanks
Alex.
9746.4 In reply to 9746.3
Hi Alex, what type of objects are you trying to select, are they curves or solids?
That script only targets solids right now. If you have only curves and no solids it won't do anything.
9746.5
thanks YEP all curves. No Problem will do it Rhino - would be good if this script could do both.
