Custom UI for PC vs Mac
All  1-3  4
9683.4 In reply to 9683.3
Hi mat, you're welcome!
> Everything seems to be working with the custom toolbar except the "LightingOptions.htm" file in the
> Command folder is not showing any of the "MajikPrimer" lighting options in the LightingPresets button
> in the toolbar. The buttons says "Lighting Options add-on not found".
I think that one depends on lighting settings having been saved in your moi.ini file by this other plugin:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.29
If you copy over your moi.ini file that will probably make it work.
> I also noticed if I change the file name of the Start Up tools...the tools are still visible
> on the toolbar. I was looking to see how to turn on/off the visibility of some of the
> toolbar buttons I'm not using, other than deleting the file itself.
I'd recommend making a sibling folder to startup, something like "startup_bak" for example. If you want to disable a startup file, move it over to that other folder and if you want to re-enable it, move it back to regular startup.
Show messages: All  1-3  4
