Hi Felipe, yes the version 3.2 trial is compatible with Mojave.
What happens exactly when you try to run it, is there an error message?
If it says it won't run because it's from an "unidentified developer", that's what the OS says when you try to run an app that is not digitally signed. When you encounter that you need to right-click on the app and choose "Open" from the menu. That will put the app on a white list and it will open normally after that.
If it's some other problem than that if you can please show some more detail about what happens I might be able to figure out what's going on.
