Dynamic Components a la SketcUP ?
9673.1
Hi. I want to pick-up with Moi3D, as being a Sketch-UP user for years, the main problem for me is that I do need a tool like the Dynamic Components to be implemented in Moi3D.
https://help.sketchup.com/en/sketchup/making-dynamic-component
It is there any chance to see such a feature in Moi3D?
9673.2 In reply to 9673.1
Hi artisanicview,
I don't know, it's tough to say what the chances are for this. But probably not anytime soon at any rate.
If that's something that you need then MoI isn't going to be the right tool for you, sorry.
Yes you can make that with Elephant by Max Smirnov : a nodes System! ;)
You can make with it any parametrical things ! ;)
And of course like DC you must code for create them or not if you want just use them! ;)
http://moiscript.weebly.com/biblio-elephant.html
Else
- Transform Array, Scale Array can be also used for some cases!
- For few specific operations you can use the EdiFrame or the function Transform / Orient / Line Line
when no new creation of number of elements is necessary!
Here the marvelous Line-Line my favorite! :)
(Uniform (uniform deformation), Stretch (deformation) None (no deformation) are possible)
EDITED: 2 Feb 2020 by PILOU
