Browsing the MoI forum with an android tablet
With a 10 inch Galaxy 6 tablet, with Verizon cellphone network connection, and also connection to home network:
Reading the MoI forum is easy.
However, to post a message, after entering the message, there does not seem to be any way to save the message to the forum.
Is there such an android button somewhere?
(I recollect posting a message by cell phone a couple of years ago. (?)
I'm thinking that using a small and light hand held real computer would be a better choice?
(MoI does not run on android.)
9667.2 In reply to 9667.1
Hi Brian, is it that with the smaller screen the "Post" button at the bottom of the type-in area is below your visible screen? If so you probably need to swipe upwards to scroll your current view of the page in order to see it.
Another thing you could try to see if it's any easier on the tablet is the "mobile" version of the forum which you can access from the link here on the login page:
9667.3 In reply to 9667.2
Test post with Android tablet, and mobile forum format
Post button is available, and works.
-Brian
9667.4 In reply to 9667.2
When attempting to post a reply in the regular MoI forum, before any text is entered, the Post & Preview &Cancel buttons are available, but as soon as any characters are typed on the android keypad, in the regular MoI forum, the text box expands to cover up the three buttons, as well as the In reply to: blue bar text. There does not seem to be any way to shrink the text box.
The mobile forum version works fine.
9667.5 In reply to 9667.4
Hi Brian, that expanding sounds kind of weird. It must be something the web browser has decided to do.
It's not unusual for a web browser to allow enlarging the text type-in field which is called a "textarea" element, but I would think it should push other stuff down further rather than covering them up.
If you tap somewhere outside the field like somewhere on the background of the page outside it, does that do anything?
Sometimes textareas are sizable by dragging in their lower right corner, that might be worth a try.
Also are you maybe able to hit a "Tab" key? That should put focus onto the "Post" button and when it has focus pushing enter should trigger it.
You also could try a different browser like Firefox:
https://support.mozilla.org/en-US/kb/will-firefox-work-my-mobile-device
