Hi Linker, thanks for reporting this.
There was a problem where if MoI couldn't decide how to sort the faces into different groups for which ones get distance 1 and which ones get distance 2, it would fall back to just using distance 1 everywhere.
This has been fixed up with this patch: http://moi3d.com/beta/Sep4_patch1.zip (unzip and copy moi_lib.dll over top of the old one in the MoI folder under c:\Program Files).
With that patch in place, MoI is able to do a better job assigning the distances to different faces, so your example should work fine with that patch in place, if you have selected edges to chamfer.
If you select the entire object instead of of edges of the object, MoI won't attempt to automatically sort it into different distance 1 and distance 2 groups, so it will still fall back to using distance 1 if the "whole object" is selected.
