Make a hole smaller or bigger
9554.1
I just stumbled over a script i made long ago..
Sometimes you have the problem that you made a hole only to find out that its to big than its a lot of work to redraw the object.
This script can help:
This hole is to big:
Select al faces of the hole and choose the basepoint (normaly the center ):
You get a cutting tool:
Change the diameter of the tool, perhaps stretch it:
And you have your smaller hole:
Have fun
EDITED: 2 Nov 2019 by R2D3
9554.2 In reply to 9554.1
Fantastic! (if that works! )
You can't move it ? (the all hole...this will be cool)
That works! (not the all hole move) :)
It's to user to make the last Diff and kill the overage?
EDITED: 1 Nov 2019 by PILOU
9554.3 In reply to 9554.2
Switch on "Keep Tool" and you can move the tool
Ralf:)
looking for moments of inspiration...
9554.4 In reply to 9554.3
Ah yes cool! :)
and for any forms! Bravo! A very cool script !!!
9554.5 In reply to 9554.4
Excellent script!
Thanks for sharing.
Mik
@r2d3
Can you give a name to the "future new hole(s)" inside your code for an easy selection for make the last Diff ?
and cool your plugin is "multiple! (we can take many different holes in the same time! )
Here the French version! ;)
http://moiscript.weebly.com/r2d3.html
9554.8 In reply to 9554.6
Yes! :-)
9554.9 In reply to 9554.8
Not yet tested but sure that will be excellent!
Merci!
9554.10 In reply to 9554.9
Works fine
Many many Thanks to r2d3 and PILOU
EDITED: 2 Nov 2019 by CHRI
Tested the new "Name": works like a charm!
Only little disturb about the all command: undo is not completly supported!
But it's yet a wonderful task!
PS You can "Copy" the "Hole Tool" anywhere you want before the last Diff ;)
Here the Hexagon on the Right is the final result of a move &/or scale of an original
You can easily Select by its name "Hole Tool" in the Browser Object by a Right Click
Now it is copyied 2 times on the Left!
Then the Last Boolean Diff can be made! (not supported by the command but it's not a big deal :)
And you can copy any separate hole (at the end they will have the same name so easy to select them!
So a new French version! ;)
EDITED: 2 Nov 2019 by PILOU
@r2d3
Seems your wonderful prog don't works for wavy volumes ?
Have you some tricks or future ideas for that ?
Now it's the big manually DIY work! :)
9554.13 In reply to 9554.12
This script relays on MOIs "SelfHealing" capabilities. Holes on curved or splited faces can't be selfhealed.
Need for Moments of Inspiration...
Have fun! ;-)
Ralf:)
9554.14 In reply to 9554.11
YES thats right...
@Michael Gibson > Do you have an idea ???
Ralf:)
9554.15 In reply to 9554.14
Hi Ralf,
I think that having an object that's created and then also deleted within the same command can mess up the automatic undo tracking.
