Keep startpoint
9533.1
it would be great if MOI would keep the startpoint.
Let me explain.
I chose the rectangle tool.
Then i set the startpoint where i need it. But, oh no. The wrong rectangle tool. I don't want the corner to corner rectangle, i want the 3-point-rectangle.
So i select the 3-point-rectangle. And now i have to set the startpoint again.
Would it be possible that MOI keep the startpoint in mind?
And this ?
keep the first rectangle, draw the wanted rectangle , kill the false...
9533.3 In reply to 9533.1
Hi Janne, I'm not sure how I would do that where it would not potentially cause other problems.
MoI can't really tell when you start a different command whether you wanted to keep some of the input from the previous canceled command or whether you wanted to do a different one in a different location.
9533.4
Hey, Michael & Pilou. Thanks for your quick answer.
Pilou, that would take "too much" time to work in that way.
If it would have been possible for MOI to keep the startpoint in mind, it would have been a great enhancement in workflow.
But, not so sad about that. I LOVE MOI since the first day.
