V4 beta Oct-10-2019 available now
 1-4  5-24  25-44  45-64  65-84  85-104  …  225-233
9526.45 In reply to 9526.44
<no not currently
So for this we can use the Max one! ;)
9526.46 In reply to 9526.34
Hi OSTexo,
> You got it, "lazy" is the right word for that Align with Dimension behavior.
There seems to be maybe a couple different bugs in linear dimension transformations, I'm investigating it.
> In that case I'd think manual flip/toggle makes sense so as not to add complexity.
I'll give this a try. I also do intend to enable turning on edit points for a dimension and moving the text position wherever you want.
> Could the existing Align tool be extended to not only effect position but also distribution?
> For example, select multiple horizontal dimensions, Align > Distribute would provide for
> spacing between dimension lines in the selected group.
The part that's difficult about this is that would have Align > Distribute processing just the dimension line and not the entire object. I guess that could be possible but it wouldn't be consistent with how Align works currently which is that it works on the bounding box around the entire object.
It seems like it might be good to instead have a "Stacked" option in the dimension command that would handle making those.
> On another dimension note do you see any potential risk for confusion by
> allowing the user to fix scale options in two places?
Do you mean for the display precision like number of decimal points to display? The setting for that in Options > General > "Decimal display" controls the appearance of the UI environment like how numbers in an edit field are displayed. It would be problematic to try and re-use that for the dimension display as well because that would mean that the dimensions in a given file would be formatted differently on what a user had set for their UI preferences.
9526.47
Great work Michael.
Maybe I lost some details, but how I can copy from details , area or volume results to leader or text dims?
(Right click not working for me)
George
EDITED: 12 Oct 2019 by GKSL4
9526.48 In reply to 9526.47
Hi George, if you click on the number for Length, Area, or Volume number it will get copied to the clipboard. Either left click or right click should do the same thing. It does not pop up a menu though since other things that would be on the menu like "Select All" or "Delete" don't really make sense there. It just gets copied with the click itself.
9526.49 In reply to 9526.48
There is no Calcul Mass * Volume ?
9526.50 In reply to 9526.49
Not currently but that's something that I would like to add in the future when I have a chance to design the UI for it. But if there are quite a lot of things to consider for it like should there be a list of materials that you pick from, do you need to enter in your own material types, is it necessary to have different densities assigned to different objects and have the mass of all of them computed together?
If all you need is a simple Mass = Density * volume calculation that is something done very easily with a calculator once you have the volume.
9526.51 In reply to 9526.50
Maybe you can just put a link to it! ;)
Like this shortcut directly inside Moi second column ;)
moi.filesystem.shellExecute( 'http://www.calculatoredge.com/matweight/material%20wt.htm' );
9526.52 In reply to 9526.51
Sorry, no it's not a good idea to have a link to a third party website like that embedded directly inside MoI. There are too many factors out of my control that can break it, like they change their domain name or even just reorganize their site so the address is a little different.
I'd recommend just keeping the link in your web browser's bookmarks.
9526.53 In reply to 9526.52
Sure...was just a suggestion :)
9526.54 In reply to 9526.48
Thank you,
Worked as described above.
9526.55 In reply to 9526.54
No problem George - I think I'll add in a little message there like "Copied to clipboard" when you click on that so that you can tell that it did something.
9526.56 In reply to 9526.18
hi
GREAT JOB Michael
Can you add something like the next GIF for small dimensions ?
Chri
Size: 22.7 KB, Downloaded: 55 times, Dimensions: 296x235px
9526.57
It seems to me the fbx export is broken. The files aren't readable by our 3D software afterwards. No matter what fbx version I choose for the export.
Currently I need t o change the date to run the previous version of MoI to be able to export to fbx. Would be awesome if you could take a look at it.
9526.58 In reply to 9526.56
Hi Chri,
Yup, probably at first it will be a manual toggle instead of an auto switching thing.
9526.59 In reply to 9526.57
Hi sconstable,
There are some other changes for FBX format, it now supports writing object names and materials to the FBX file.
What is the other software that can't import them now?
You can disable the materials export by a setting in moi.ini :
[FBX Export]
WriteMaterials=n
Does that make any difference with that set?
Can you please post an example .fbx file that isn't read by your other software?
9526.60
As I am becoming more familiar with how these dimensions work I am also realizing what a clever and potentially powerful implementation it is. And it's actually not that difficult to add dimensions to a 3D model should you choose to do what's not allowed ;)
9526.61 In reply to 9526.60
And with the Cplane you can dimension any 3D thing not orthodox mechanical drawing! ;)
9526.62 In reply to 9526.60
Hi Terry, that sure is looking nice! Now if you can make a PDF that looks like that too that's going to be pretty convenient.
So maybe the key to making the "forbidden style" easier is to have some more options for setting the construction plane. Maybe something like a "quick cplane" that will set it to a select face just for the duration of one command and then automatically restore it. Something to experiment with after v4 is wrapped up.
One of the problems with not projecting them is that it's pretty unexpected I think to place dimensions in an ortho view say like this:
And then to get this type of result:
When I saw that happening it was kind of "uh-oh that's probably not so good".
But if you really want to give non-projected a try it's actually possible to do that. Edit the text file DimLinear.js inside the install commands folder, and on line 7 change this:
    pointpicker.projectToCPlane = true;
to this:
    //pointpicker.projectToCPlane = true;
9526.63 In reply to 9526.62
>Now if you can make a PDF that looks like that too that's going to be pretty convenient."
Yes, that is key to being able to communicate fabrication details and I'm looking forward to it.
>So maybe the key to making the "forbidden style" easier is to have some more options for setting the construction plane."
Maybe. Don't get me wrong. I agree with what you are saying. It's just that sometimes it's helpful for the guys who will be building your design to ALSO see the dimensions on a 3D view. I was just saying that it's not really difficult to draw them directly in the perspective view with the current implementation. If you have ideas to make that even easier, great but only if it's not too difficult and time consuming. I'd rather you got the export function going. I prefer to export as AI for formatting rather than directly to PDF.
By the way, I love the fact that the dialog can stay open while you work. I would just like to be able to set up defaults and maybe be able to save multiple setups.
Great work and thank you.
Terry
9526.64 In reply to 9526.63
Thanks Terry,
AI and PDF are similar enough that they should be able to use the same mechanism between them.
The thing that's most problematic is text, PDF/AI does not allow a full 4x4 matrix transform on text, so for a perspective view the regular postscript type text entity isn't usable for perspective text, it has to be rendered some other way.
Yup, this is the next area of work. This will probably be going in the Options dialog where you will be able to create some presets of annotation properties and then in each annotation command there will be a Preset: dropdown where you can choose which one you want to use for that one you're making.
Maybe one preset named "Default" will get stored in your moi.ini file so it's there for all new projects and other presets will be stored in .3dm files.
I'll know more once I dig into it some.
Show messages:  1-4  5-24  25-44  45-64  65-84  85-104  105-124  …  225-233
