V4 beta Oct-10-2019 available now
 1-16  …  177-196  197-216  217-233
9526.217 In reply to 9526.216
Hi hunter, there should be another beta out within a few days I hope. There will still be one more beta after that before the final one. There is still some stuff to finish up with dimensions.
9526.218 In reply to 9526.215
Hi Michael, On my main workstation I have 1 34inch widescreen as my main screen - replaced 2 screens but I use a wacom touch screen which is positioned below the widescreen so a little different to your horizontal multi screen setup. I would say as the widescreens come down in price multiscreens setups will drop off not having a join in the middle is so much better.
thanks again.
9526.219 In reply to 9526.218
No way I would replace my multiple screens with a wide screen. 2 screens give me 2 distinct areas that I can maximize windows to. 4 if using Windows+Arrow-Left and Windows+Arrow-Right.
9526.220
I apologise if this has already been discussed. I use MoI for exporting CAD via LWO to Modo. It's great! But I've noticed in the V4 Beta that I'm getting a lot more problems with flipped polys in the export mesh than I do in V3.
Ideally I would just use double-sided materials in Modo/VRay but then there's problems using rounded edge shaders because of the surface normals, so I have to go and flip any problem polys by hand (which can take a long time!)
Cheers,
Will
9526.221 In reply to 9526.220
Hi Will, do you have an example model that you can post here or e-mail to me at moi@moi3d.com that behaves differently in the mesh export between v3 and v4?
Thanks, - Michael
9526.222 In reply to 9526.221
Thanks Michael, I've sent you an email with a test file.
Cheers,
Will
9526.223 In reply to 9526.222
Hi Will, thanks for sending the test file. I can repeat the difference between v3 and v4 with your file. It appears to be caused by differences in the joining process when importing an IGES file.
For IGES imports, V3 would only attempt to join edges to other edges where the edges matched each other at their endpoints.
In V4 this has been modified so that during the joining process it will also try to split edges at "T" junctures so those will join as well. This is however going poorly with your file here, it's making things like little tiny edge fragments which then makes for an ambiguous face adjacency traversal later on which is used to gather faces on the same side of a non-solid joined surface for orienting normals.
I will send you a v4 test build that restores the same behavior as V3 for IGES joining. If that works better I will revert this v4 change back to v3 behavior.
9526.224 In reply to 9526.217
Thank you Michael,
The dimension feature problem makes life harder. When the new beta version will be out?
9526.225 In reply to 9526.224
Hi hunter, sorry it's hard to know exactly when, when I get bug reports in I often stop and fix those up so that can delay things a bit.
Hopefully just a couple more days here.
9526.226 In reply to 9526.224
Ok, I've got the strategy for preset dimension properties worked out, there will be a new "Dimensions" section of the Options dialog. I've got the dialog working but still working on some of the plumbing. It's a little complicated because these settings can be modified while you are in the middle of running a command.
The "default" preset is for global dim properties, it is stored in the moi.ini file. If you want to use the same settings across all projects then this is the one you would set. You can make additional presets that will be stored in a .3dm file if you want to project-specific settings.
It's close but probably won't be finished today:
9526.227
Looking good - I mostly port my drawings into Rhino or Solidworks for dimensioned detailed drawings but really looking forward to be able to pump out simple drawings straight out of MOI. Great addon.
regards
Alex.
9526.228 In reply to 9526.227
Thanks Alex! Yes, without line types and hatching it won't quite be suitable for detailed drawings but it should be very quick and convenient for simple drawings.
I hope it will be useful!
9526.229
Looking awesome Michael, looking forward to it!
Should be able to get it out tomorrow.
9526.231
Bravissimo !
9526.232 In reply to 9526.230
Wonderful!
I just spent the day laying out a floorplan to share with an architect and found the dimensioning tools to be so easy to use and intuitive.
Thank you, Michael! Really looking forward to using this more in the future.
9526.233 In reply to 9526.232
That's great Rio, I'm glad you are liking it!
Show messages:  1-16  …  157-176  177-196  197-216  217-233
