V4 beta Oct-10-2019 available now
 1-3  …  84-103  104-123  124-143  144-163  164-183  …  224-233
9526.124 In reply to 9526.123
Hi Sven, thanks for letting me know what was going on with the FBX import.
Does that mean that you don't need any option for stripping out extended characters from object names then?
I've also taken a look at why the names are so long, it's because there is this property in a "Product name" and that's getting added to the name as well (sometimes twice I guess) like "Product name: component name". I've updated this for the next beta to only get the component name so I think that should help avoid getting tremendously long names. I'll put in an option to have the long names (with duplication removed) if that was useful for someone.
9526.125 In reply to 9526.124
Well, I'd say it's always a good idea to filter them out but thats more from a general perspective. At one point or another they'll cause problems in a pipeline and to be honest, no one needs them.
So it would be a nice feature to have that option, yes. Do I absolutly need it right now? No, because I can alternatively remove names entirely and that's good enough for me.
- Sven
9526.126 In reply to 9526.125
Hi Sven, ok I'll leave that option for stripping extended characters in then.
9526.127
Hi Michael.
Thanks for the recent update.
I have a question about the SubD From File import option.
I was wondering if your implementation was similar to Catmul-Clark and if so, is there an edge weighting option that we can use to tighten up the mesh?
I have a model in modo that is all quads and all verts are merged. No open boundaries.
When I convert to Catmul-Clark subD with not edge weighting I get this result.
Were I want tight lines and or corners, I simply apply edge weighting.
When I import this model into the latest v4 beta I get this result.
This looks very similar to the conversion to Catmul-Clark in modo without the edge weighting.
My question is, is there a way to apply such edge weighting in Moi upon or after import of such a file?
-s
9526.128 In reply to 9526.127
Hi Scooter, yes the sub-d conversion is almost the same as Catmull-Clark, the only differences are at extraordinary vertices.
There isn't currently any way to set the edge weighting in MoI but that is something I want to work on in the future. Additionally the .obj file format does not itself have any method of representing edge weighting so any transfer through .obj format will not preserve edge weighting anyway.
FBX format does have a way to store edge weighting and that's a format that I want to add in the future.
9526.129 In reply to 9526.128
Michael,
I thought the edge weighting could be something like Max's SubDiv Beta 9 script, where one uses a slider.
I'd rather see this for imported OBJ files, as opposed to relying on the ever changing proprietary FBX format.
Thanks for the consideration.
-s
9526.130 In reply to 9526.129
Hi Scooter,
Just a slider after the import does not seem very feasible to me since there isn't any control over what edges are being targeted.
In the future I would like to have it so importing an obj file would result in creating a special sub-d type object in MoI where you could turn on control cage points and move them around, adjust edge weights, etc... For now when there is not the infrastructure in place for making those types of objects it just makes a regular NURBS object.
9526.131 In reply to 9526.130
"... In the future I would like to have it so importing an obj file would result in creating a special sub-d type object in MoI where you could turn on control cage points and move them around, adjust edge weights, etc..."
That, I would like to see. It would take MoI to a whole new level.
9526.132 In reply to 9526.130
That sounds feasible to me Michael and would be much appreciated.
Until then, I'm attempting to have the current importer give me the results I'm looking for.
What I've done is to unweld all of the points of my object, in order to take advantage of the "SubD import options" "Open Boundaries" "Keep Corners"
When I import this file into Moi, it sees that all faces are open boundaries and thus retains the sharp corners.
Then, moi appears to weld the patches back together and a create a Solid for me.
Not certain if this has resulted in a true NURBS object though.
Can you test the attached file and let me know what was created?
-s
9526.133 In reply to 9526.132
Hi Scooter,
Yeah it's a NURBS object, although a kind of oddly structured one with a lot of little surface fragments instead of large smooth surfaces.
9526.134 In reply to 9526.133
Michael,
I build all of our models in a DCC app and occasionally am asked to create an equivalent CAD model.
In the ongoing attempt to convert a quad poly mesh into a CAD model, I thought I was onto something.
Perhaps I'm misunderstanding the whole point of the SubD importer.
Just what should I expect as the result of the import?
Is it just a background mesh to build off of?
Would like to avoid having to completely rebuild it.
-s
9526.135 In reply to 9526.134
Hi Scooter, the primary job of the sub-d importer is to enable a hybrid workflow where you can incorporate some sub-d elements as parts of a semi-organic model.
Say for example you want to do a space helmet and you want to start with a smooth base head shape that you'll then boolean some details onto. The head shape can be easier to do as a sub-d surface, and with the new importer you are able to use a sub-d modeling program to make the head surface and then import it into MoI and continue to build more elements off of it.
So basically it allows for using a combination of both sub-d and NURBS modeling techniques in a single project.
You should see a NURBS object in MoI that looks the same as the sub-d limit surface in your sub-d modeling program. But it does not currently support edge weights.
You mean like a template guide that you're going to throw away? That's not really the main idea, it's more about using the sub-d surfaces directly as part of your model.
9526.136 In reply to 9526.135
Thanks for your patients and explanation Michael.
Keep up the great work!
Looking forwards to the final V4 release!
-s
9526.137
Sorry if it has been said before, but....I think that the option "From object" in Dim must be checked -not pushing the button each time- in order to keep this option active while the dim task is doing.
BTW, again a amazing version!
9526.138
Have you changed the size input field so the prompt as at the end of the field rather than at the beginning - I have always used those fields with tab key and type over current settings but now need to backspace to clear field before new entry?
thanks Alex
9526.139 In reply to 9526.137
Hi David,
> dim task is doing.
Unfortunately a checkbox option is not quite feasible here. If you start out with nothing selected, then setting the checkbox would need to ask you to select an object. That selection is an additional stage of the command and the global UI convention in MoI is that setting a checkbox state should not cause a new stage of a command to be entered, that's always done by a push button, not a check button.
It is possible though to set up a keyboard shortcut that will automatically trigger the "From object" button so you don't have to click it separately.
To do that set up a shortcut key with one of the following:
DimHorizontal FromObject
DimVertical FromObject
DimAligned FromObject
Those keyboard shortcuts will be the same as running the command and clicking the FromObject button.
9526.140 In reply to 9526.138
Hi Alex,
It wasn't intentionally changed to do that. I can't seem to make it happen over here, does it only happen when the new object properties dialog is open?
9526.141
In MOIv3 if you go and change an objects dimensions the starting position for the prompt was at the beginning of the field but now for some reason in V4 when I go to make a change it defaults to the end of the input field so I have to backspace to clear that field.
Alex.
9526.142 In reply to 9526.141
Hi Alex, how exactly are you activating the input field, is it by pressing the Tab key? Clicking on it? Or just typing keystrokes immediately after opening the edit size menu?
Thanks, - Michael
9526.143
Any suggestions for a screen capture format or program that I can use to display problem?
Show messages:  1-3  …  64-83  84-103  104-123  124-143  144-163  164-183  184-203  …  224-233
