Hi flippyfloop, actually a juncture like you've got here is quite difficult for the fillet engine to handle:
I'm not sure why it was working ok for Chipp, maybe he was just lucky.
I'd probably try doing it with regular non-variable radius fillet but in 2 passes, first do this one:
Then this one:
Most of the time it's not so good to do filleting in multiple passes where the fillets run into each other but in this particular case it helps things because it makes the filleter avoid trying to build a juncture patch at that pointy tip area.
The thing that's difficult about that kind of pointy shape in one pass is it wants with normal fillets to make things like this:
Then it wants to make a smooth connection between those pieces but they're going at an opposite 180 degree direction from each other and it's an awkward situation to try and put in a connector patch.
