Models and Renders
946.1
I don't know if this is a model question or a render question as I am very new to this.
I have modeled a cylinder in MoI with a groove around the circumference.
I want to render it such that the cylinder has one material (color) and the groove has a different material.
I don't see a way in Bryce to select just one feature of an object and selectively apply the material.
Are models rendered with multiple materials created as multiple objects, or am I not understanding how to selectively apply a material?
By the way, MoI and Bryce are a very nice combination. I hope to post a picture here soon.
Ed
946.2 In reply to 946.1
Hi Ed, usually most rendering programs offer some way to select different polygons out of a model and apply a different material to them. But I'm not familiar enough with Bryce myself to know where or if this is provided over there. You'll probably have to find a Bryce forum to ask about that.
But one thing you might try - I wrote a little program that you can download here: http://moi3d.com/download/SeparateOBJ.zip - if you run that program it will edit an OBJ file and it will break objects up into smaller objects along any sharp edges in the shape.
Then when you import that OBJ into Bryce, it will probably come in as separate objects and that may make it easier to assign different materials.
946.3 In reply to 946.2
Thank you - your program worked very well on my model.
I found information in the Bryce forum and apparently there is no way to select just part of a mesh to apply a material. Your program broke my object into 4 objects and I was then able to select each and apply different materials in Bryce.
The key word in your program description is "sharp edges". I ran the program on a model with curved surfaces and radiused corners and it did not break apart.
Is there any possibility in the future for the user to select an area directly, or perhaps define the threshold, for object division?
Regards,
Ed
946.4 In reply to 946.3
Hi Ed, I am glad it worked to fix up that one model to work how you wanted.
To be more precise, it goes through the OBJ file and makes a separate object for every "smoothing group" that it finds.
When MoI exports an OBJ file, there will be one smoothing group defined for each connected chunk of polygons that share the same vertex normals.
Polygons along a sharp edge get different normals, so they create boundaries between different chunks of polygons, separating things into different smoothing groups.
There is also another way you can create smoothing group boundaries - by turning off welding.
When you save to an OBJ file, the "Meshing options" dialog will pop up that has the slider on it that you can use to adjust the density of the generated polygon mesh. In the bottom-left corner of that dialog is a little double down-arrow, if you push it the dialog will expand with more options.
One of those additional options is "Weld vertices along edges" - by default this is turned on, but if you turn it off then the mesh that is generated for each surface of your original solid will have separate points instead of sharing common points along edges. This will also have the effect of further dividing smoothing group information so that each separate surface (whether it has sharp corners on its edges or not) will be in a different smoothing group.
So if you turn off welding it should help you break down smooth objects as well.
The only difficulty is that some programs may create a visible crease in between unwelded areas that are supposed to be smoothly shaded, if they try to calculate shading information manually instead of using the shading information directly from the OBJ file...
Yes, there will definitely be some work on this for version 2.0 - I'd like to make it possible to assign different basic materials at least to different faces and then export those material assignments to the OBJ file. Hopefully Bryce will read that data from the OBJ.
