default diameter
9428.1
Mi all,
is it possible somehow (didn't find in ini file) to have default parameter Diameter instead of Radius when drawing circles?
Thanks.
Yuri
9428.2 In reply to 9428.1
yes
click on radius :)
9428.3 In reply to 9428.1
For center circle, after selecting center, or tan_tan circle, after selecting the two tangent points, click on "Diam", which will then change to "Radius".
A second click, on "Radius" reverts to "Diam". It is very cool.
I think what Yuri is saying is that whenever you draw a circle, the measurement defaults to radius, and you have to click to switch the value to diameter.
I would also like to see an ini setting to default to diameter. Most of the circles I draw are for bolt holes, and therefore I'm looking to directly specify a diameter.
9428.5 In reply to 9428.1
Hi Mr. Yuri, yes it's in the moi.ini file under:
[Commands]
UseDiameterDefault=n
Switch that to =y and then it should use diameter as the default radial input method.
9428.6
Thanks Michael,
that's what I've been lookin for ;)
