Last April, I had installed Marco's UI in MoIBetaV4, with the S_Gallery icon at 80 px, instead of 96 px.
Michaels update to ScriptsGallery.htm now permits Marco's UI to work!
I think that step 5 should be to the AppData command folder(?)
I think that I am missing some Commands and Scripts, accessible from Marco's UI, so may need to copy them to AppData.
For MoI4 in general, Apparently the standard MoI commands need to be located in the MoI install folder?
There is also a copy in Appdata, which I think can be deleted.
Non-standard commands, with _ prefix, are located in Appdata.
For BlendCap of an extruded cylinder, the end circle needs to be deleted, NOT merely hidden, to get the "domeCap" with BlendCap, in both MoI3 and MoI4beta.
In general, I am liking the Marco's UI. Maybe for MoI5 an elaborated version?
Edit, copying Marcos "Scripts" directory to MoI Install directory did not enable, for example, Morph between Curves.
Nor did it help to copy Scripts directory to AppData.
No more experimentation tonight :-)
