Hi Adam, switching between a sharp vs smooth point isn't really something that needs to be done very frequently so it would not be a good target to try and optimize for a gesture-type quick access.
Points on/off is also similar, usually when you have points on you have them on for a while, it's not very common to want to turn on control points for just one second and then off again. So it's also not really a good target for a shortcut action either.
It tends to be bad overall to try and optimize actions that are not actually needed very frequently.
I'm still not sure what to do with double clicks though, I kind of like to stay away from them. Maybe if I can't figure it out at some point I could set it up so you could customize it. But they might be needed for some groups or instance editing functions though.
