Backup script
9386.1
Hello guys,
I don't know if that's possible in MoI but it would be nice to have a script/feature similar to "stash" feature in Blender MeshMachine add-on.
Basically you can create backups of your selected mesh as you go. When needed you can cycle through previous states (using a slider for example) and replace or bring back an older state of the object.
The backup objects are hidden from view.
And of course a button to clear all the backups for the selected object.
9386.2 In reply to 9386.1
Not exactly that you want but ...some rustic & efficient! ;)
You can launch any number of sessions of moi!
And make some Ctl +C / Ctrl + V if needing for copy past something between them!
Nice trick Pilou !
Never think about it, but it's a good trick.
My solution for my models is to copy/paste in the same file, but it could be limited...
9386.4 In reply to 9386.3
That also works. Save Incremental command helps in that case.
Thanks Pilou,
9386.5 In reply to 9386.1
Hi Stargazer, I have some ideas for future work similar to that but it will take a lot of effort.
For now, yes IncrementalSave is probably the closest type of thing.
