Best way to select edges curves?
9385.1
Hi everyone I'm new to Moi3D so far I've been following a couple of courses and tutorials that I found and it's all good, I'm in love with the tool. Now there is this thing that it's been bothering me and that is the time it takes me to select curves, in 3D apps like Modo I'm used to select edge loops, I understand it's not the same but nevertheless I was wondering if there was in Moi a way or script that could automate the task of selection edges. Thanks!
9385.2 In reply to 9385.1
script:/*Loop selection*/moi.geometryDatabase.selectLoop();
Copy above on the second column of shortcut! ;)
9385.3 In reply to 9385.1
Hi ColoristNow, also if you select one edge then you can do a selection window drag which will then target edges.
If you have an example model where you're having difficulty selecting edges if you could post the model file I may be able to give some suggestions.
9385.4
Thank you very much for the help, have a nice day!
