MORPH closed Curve script
9382.1
Hi All wanting to create a morph sequence from a set 2 closed curves (triangles) have found the Morph between curves script but seems to only open curves.
Does one exist?
thanks
alex.
9382.2 In reply to 9382.1
Hi Alex, does it work to use Edit > Separate on your 2 triangles and then pick 2 lines at a time?
Or do the pieces not match up?
9382.3
Hi Michael - thanks for the advice I ended up lofting the shape between the 2 shapes and slicing the lofted solid to get the planar slicers. This would be a handy script if someone had some time to write it. This is illustrators offering.
9382.4 In reply to 9382.3
Hi
This scrip exist, it's cMorph written by Max.
http://moi.maxsm.net/files/
EDITED: 9 May 2020 by FINEMA
9382.5 In reply to 9382.4
Thanks Finema - the OLD C infront of the MORPH throw the search path off course - thanks for highlighting the pathway.
Works perfect.
