MOI & BSOD!?
9329.1
So, I've had my machine completely freeze and then BSOD over last week or so. Both time's when using MOI3D.
I've been running other apps fine, C4D with Octane / Redshift, Photoshop, AE, etc..
Very odd but I'm now kinda scared to run MOI. Any help would be appreciated.
9329.2 In reply to 9329.1
Here's the .dmp file & screenshot.
Size: 49.6 KB, Downloaded: 43 times, Dimensions: 527x439px
9329.3 In reply to 9329.2
Not enough info to get a real solution, but usually something like this is due to the video drivers. Try updating them first...
9329.4 In reply to 9329.1
Hi flippyfloop, the crash dump indicates the crash happened in nvlddmkm.dll which is indeed part of your video driver software.
So the main thing to try is to do a video driver update using the latest ones available from the nvidia web site.
If you keep seeing it a couple other things you might try are to look in nvidia options and see if there is an option to disable "threaded optimization" and also in moi.ini you could try setting DisplayThreadLimit=1 in moi.ini to turn off multiple threads in the display engine as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9021.6
9329.5 In reply to 9329.4
Thanks Michael.
I'll try this out later today. Fingers crossed.
