Moi to Rhino issue
9321.1
Ahoy, I've run into an issue when exporting moi files to be opened in Rhino6.
For the most part, transferring between the two is hassle free, providing I make sure the unit system matches.
However, when importing more complex Moi files into Rhino, I find the simplicity of the Nurbs is lost. Many of the curved surfaces are divided up into multiple segments. The attached image should explain what I mean.
I've tried exporting in all formats available with same results.
Cheers! - J
9321.2 In reply to 9321.1
Hi Jez - your surfaces aren't being actually divided there, that's just how Rhino's default display works since it was originally designed as a wireframe display.
Those additional dividing lines are drawn by Rhino across a surface so that there would be a way to visualize the surface with wires displaying only.
You can turn them off by selecting the objects in Rhino and going to properties > Isocurve density and uncheck "Show surface isocurve". That should stop those additional wires from being displayed in Rhino.
9321.3 In reply to 9321.2
Legend! Thanks Michael
