Hi Eric, thanks for sending the file. I tested it with Rhino and ViaCAD and saw the same problems in both of those as what you show in MoI.
The main thing that could cause those kinds of gaps to open up is if SolidWorks thinks the surfaces in those areas are planes yet the trimming boundaries around them are some fairly large (larger than an expected tolerance amount) away from that plane.
You might try the "Check entity" command in SolidWorks:
http://help.solidworks.com/2018/english/solidworks/sldworks/hidd_check_entity.htm
and see if it complains about any way out of tolerance trimming edges.
Another thing you can try is a setting for IGES export in SolidWorks:
http://help.solidworks.com/2018/english/SolidWorks/sldworks/hidd_export_options_iges.htm
Try the option for using “Trimmed Surface (type 144)” and maybe "Use high trim curve accuracy".
Also for IGES using type 144 trimmed surfaces maybe only export one solid at a time, not multiple separate objects in one single file because they will be all individual surfaces and if surfaces from 2 parts touch each other they can interfere with each other for getting joined together.
Does that make any difference? Also does re-importing the IGES with type 144 trimmed surfaces back into SolidWorks give the same gaps? If so then the problem is likely that it's a badly formed model in SolidWorks to start with, with trim edges way out of tolerance from their plane surface.
