Hi skipper, so the Move command has 2 point a "base point" for the spot on the object that you want to move, and a "target point" for where you want to move it to.
So for your first point you need to get a point on or near the object. Like Stefan writes above the easiest way to do this is to push the "Bounding box center" button which is the command options area underneath the "Pick base point" prompt:
Push that button for the first "base point" point pick and that will take the center of the object's bounding box as the base point.
Then for the target point you can either use the mouse with object snap to pick the 0,0,0 origin as the target point, or you can also type in 0 and push enter. Typing 0 <enter> is a shortcut for 0,0,0 .
