Some documentation available now
 1-20  21-40  41-48
931.41 In reply to 931.37
>>If you think anything ... is missing please let me know!
Maybe some mention of using Esc key to deselect objects, hide control points and cancel a command....
Petr
931.42 In reply to 931.41
Good idea Petr. I was just thinking where to mention it, maybe under Shortcut keys, and maybe also under Deselect all and Show Pts.
It will also probably be mentioned in the introduction section which will have sort of an overview of how commands work in general.
About the command Align for Points
Seems you must add in the text for 'Vertical mirror' there is a crease when the 2 last points are not align
because when you make a symmetry along the 2 last points(not horizontal aligned) there is no crease :)
931.44 In reply to 931.43
Hi Pilou, I've added a note in there to clarify this, it will now read:
"An example of aligning control points in preparation for mirroring around the vertical axis."
931.45 In reply to 931.44
:) Now no possible confusion :)
In the command Transform / Array /Circular we can read
"This can be used to create sprial type patterns"
I suppose that is spiral :)
931.47 In reply to 931.46
Thanks Pilou, yup that was supposed to be spiral - fixed now!
About the Helpers lines seems you must add a little line before the use of the little marker :)
for say that you can use the Numeric Calculator for Distance and Angle box
This distance will block the helpers lines next point along it, and angles will makes steps rotations around the first point clicked+drag with angle input it.
Some powerlful indeed!
EDITED: 30 Sep 2007 by PILOU
Show messages:  1-20  21-40  41-48
