OBJ export.. skip PartTag and UVs.
9277.1
Hi there,
I wonder if that could be added as an option.
When even I import OBJs or LWOs exported from Moi3D I get UVs and PartIDs (whit the name of the Surface).
Both causes bigger files and performance. So I delete them. Now on bigger files this can be quite time consuming.
Unfortunately I haven't found an importer that does skip these two parameters. At least not in the software I use.
So, if possible, I would love to have this optional in Moi3d to leave out both.
Robert
9277.2 In reply to 9277.1
Hi Robert, for .obj files there is an option in the UI for disabling writing material assignments, under Options > Import/Export > "Obj options" > "Write material assignments".
You can also disable writing UV coordinates for .obj files by a setting in moi.ini - go to Options > General > "Edit .ini file" button and inside moi.ini find [OBJ Export] WriteTextureCoordinates=y and change it to =n like this:
[OBJ Export]
WriteTextureCoordinates=n
There is also a similar moi.ini setting for disabling UV coordinates to LWO format:
[LWO]
There is not currently a way to disable writing material/surface assignments to LWO files but I will see about adding that in.
