change the up axis to Y?
9258.1
hi, when I import a step file (what I have to do realy often) all resultet meshes are rotated 90 degree clockwise.
And the coordinate system shows Z as up axis, what is wrong for step files, for maya and for me :(
So every fbx, which I import in maya, I´ve to rotoate first.
Not the big thing, but is it possible set generally the up-axis to Y?
Taht would be very helpfull.
Thanks for hints
9258.2 In reply to 9258.1
Hi Kompo, are the step files made in SolidWorks? Most CAD programs use z-up like MoI does except SolidWorks.
There is a setting you can modify in moi.ini :
[NURBS Import]
RotateYUpToZUp=y
which should help, see here for more details:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3250.6
There is a way in MoI to change the axis labels to any direction you want, under Options > View > "Axis label options", but it only affects the labels shown in viewports and numeric point input, not how file translation happens.
9258.3 In reply to 9258.2
Michael, thanks so much.
That was the soultion.
Now it comes to maya with the correct up-axis.
