changing dimension
9255.1
Hello,
is there any way (or plugin) that will allow me to show dimensions, like "dimensions" plugin.
But when I modify the part (extrude a side for example) the dimensions will change as well displaying the new correct value?
9255.2 In reply to 9255.1
Hi Mr. Yuri, sorry no I am not aware of any plug-in that would do that, it would be an extremely complex task to implement in a plugin.
If you want to edit a sketch by dimensions check out SolveSpace, it is heavily focused on constraint based sketching and you should be able to export your sketches to IGES format if I remember right.
9255.3 In reply to 9255.1
You can also use the free Design SPark Mechanical for make some measures before some new version! ;)
(and it makes that you ask ;)
https://moi3d.com/forum/messages.php?webtag=MOI&msg=6186.53
(will be also useful for Moi's critic fillets! ;)
EDITED: 11 Feb 2019 by PILOU
