Hi Lish, here is one idea.
I started by drawing a curve in the front view. I used grid snap on this one to make the kind of regular wavy pattern:
Then Construct / Revolve can be used to turn that profile into the main body of the water bottle:
If you want something that has a very regular shape, that can finish it right there. But if you want those kind of knobby feet on the bottom that is a bit harder. To make some knobby feet shapes, I drew another smaller outline and used revolve again to make one foot:
I then positioned this foot so it was off center and also moved it upwards so it intersected the main body part:
Next I selected the foot, and used Transform / Array / Circular to make it 4 copies around the center of the bottle, then selected the 4 feet and the main body and used Construct / Boolean / Union to fuse them together. After the boolean there are new edges formed where the foot intersected the body, I selected those:
Then I used Construct / Fillet to round off those sharp edges. Fillet tends to be a bit sensitive, if you have too many things running together or gaps between objects, stuff like that, it will tend to cause problems with fillets. Here is the result of filleting:
So the end result - proportions are kind of off, but you can get the idea. You may want to bring in an image of your water bottle as a backdrop with View / Image so you can get the proportions right:
Hope this helps!
