Recessed Lettering on a Cylinder
All  1-3  4-9
Seems to me that you can project your texte like a real wraping with the function Construct /Curve / project :)
In some action
project up line curve of the letter on one cylindric surface
project down curve line of the letter on one less cylindric surface
reconstruct the letter
Make boolean Cylinder / new letter = your real wraping text :)
Here you have just make a "straight" projection not a "rotative" projection :)
EDITED: 16 Sep 2007 by PILOU
924.5
You can do it, its just an extra step.
Project the wires of the lettering onto the surface of the tube.
Then you create a solid from the projected wires
(that's a few extra steps)
then boolean the new letters from the surface.
Mike Fitz
www.3dartz.com
924.6
there is a free download for curving text www.deskam.com go to downloads then {"desk engrave" it's free hope this will help it will save as a dxf or g code
924.7 In reply to 924.6
the only detail is that you can't put it inside Moi :)
924.8 In reply to 924.5
After you project the letter curves, if you trim your original surface with them, you can extrude the new letter surfaces using *Set dir* , *Cap ends* and *Both sides*
to create a cutter that will boolean out from the original object at a consistent depth, while following the contour of the surface.
jdkjewelry3d.blogspot.com
924.9
Excellent! I hope these kind of tips find their way into the MoI documentation :)
Ed
Show messages: All  1-3  4-9
