exporting 2d
 1-7  8-27  28-47  48-50
918.8 In reply to 918.7
Hi Paul, I cooked up a converter for you, you can download it from here:
http://moi3d.com/download/3dmCurves2DXF.zip
Unzip this to some folder, then run the 3dmCurves2DXF.exe program.
It will ask you for the name of an input .3dm file, and then the name of an output .dxf file.
It will read through the input .3dm file and convert any curve objects it finds to Spline entities in the DXF file.
Please let me know if this works to transfer your curve data over.
918.9 In reply to 918.8
Hi Michael ,
Superb !!!!! and a big thanks for the work .
I'll be running some tests right away and I'll let you know .
Greetings ,
Paul
918.10 In reply to 918.9
Michael ,
First of all thank you very very much for the mini 3dm to dxf convertor .
It works quite well and it should be just right for my purposes .
I opened it in Turbocad and some other programs I have ( freeware , alibré x press, solidedge 2d ).
The splines that replace the curves are wel in their place .
This mini 3dm to dxf convertor will do the job for me I hope it will be usefull to somebody else also .
I'll keep the forum informed about my guitar building process with Moi .
Paul
Works like a charm ! Even the curves 3D (is that normal ?
Bravo!
918.12 In reply to 918.10
Hi Paul, that's great, I'm glad that it will help!
I'm looking forward to seeing some guitar stuff, it would be very interesting if you could take some photos of different stages in the process and post them.
@Pilou - seems like this converter may help in more situations than I had thought!
I'm still planning on doing a much more comprehensive DWG and DXF export for version 2, but this seems to be a good step for transferring curve data to apps that don't support IGES.
Yup, it will convert any kind of curve, either flat or 3D.
918.13 In reply to 918.12
Michael ,
I tried a 3d file and it partially worked .
I'll do some more tests on it in the next days and let you know .
Paul
< seems like this converter may help in more situations than I had thought!
yes but after for use it, it's not so evident in the case of curves 3D :)
Yet by the simple aspect thats great, but for use it as entity it's another story :)
because they don't define a planar surface :)
918.15 In reply to 918.13
Hi Paul, just to make sure we are talking about the same thing - by 3D I meant curve objects that might swoop around with different z values, instead of just being flattened on the xy plane.
Here's one example:
I didn't mean models with surfaces or solids like a sphere or solid box.
If you do run into any problems, please send me a .3dm file with the problem curve in it.
918.16 In reply to 918.15
Michael ,
You're right I converted a file with surfaces and some curves . that's why I tought I was missing some lines and curves because they were actually surfaces, and the lines that were still there were the start lines and curves I made before making surfaces with them .sorry about that !!
I'll try some thing in the next days .
Paul
918.17 In reply to 918.14
This script macro might be useful for some data transfer stuff - this will duplicate every edge of every surface or solid in the scene as a regular independent curve object. Those curve objects can then be processed into DXF using that utility.
You can do this manually by selecting all the edges and doing copy/paste, this just makes it easier to process everything with one keystroke if you've got multiple objects.
script:var breps = moi.geometryDatabase.getObjects().getBReps(); for ( var iBrep = 0; iBrep < breps.length; ++iBrep ) { var brep = breps.item(iBrep); var edges = brep.getEdges(); for ( var iEdge = 0; iEdge < edges.length; ++iEdge ) { var newedge = edges.item(iEdge).clone(); moi.geometryDatabase.addObject( newedge ); } }
To use it, go to Options / Shortcut keys and set up a new one, paste this in as the Command part.
918.18 In reply to 918.17
That's works again here from a cube solid :)
each cubes' Edges are divided in small edges
EDITED: 13 Sep 2007 by PILOU
But when you select all a face you can create a real face 3D:) (in google Skechup)
(cubes' edges are always divided)
918.20
Hello ,
I just tried the macro script and it all works well . Now I can see all the edge curves of the surfaces when I use the convertor to DXF.
Many thanks ,
Paul
In fact i have found a plugin for Sketchup who repair the "lines broken colinear" so that solve my problem for the straight lines on the 3dSpace :)
If someone is interested that is that http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/repair_broken_lines.rb
For a 3D curve no linear seems that is more difficult to use it for build a surface :)
But maybe exist a new ruby script who knows? :)
918.22 In reply to 918.21
It is strange that it breaks the lines in the first place... I wonder why they decide to do that?
They may process Line entities instead of Spline entities better. There are a lot of different ways to store stuff in a DXF file, right now that converter just exports everything as a Spline object, but for version 2 I want to add an option to output stuff like line, circle, and arc entities instead of everything as a spline. That might help for some situations.
918.23 In reply to 918.22
In fact a simple line from Moi in 3dm converted in DXF is imported in Sketchup as a "Component"
So when you explode it you have these divided lines ! (Mysterious I am agree :)
918.24
Michael ,
You can also sign me up for version 2 .
By the way How do I turn screenshots of moi into a Jpeg so I can put them on the forum for documentation ?
Paul
918.25 In reply to 918.24
Hi Paul, I usually use PaintShop Pro for doing that. There are other image utility programs you can also use, some of them free like IrfanView.
But it is also possible to do it just with stuff built in to Windows - you can push the "Print Screen" button on your keyboard to put a snapshot of the screen into the Window clipboard, and then run the old Windows paint program (pbrush.exe), and inside there do a Ctrl+V to paste the image in from the clipboard, and then save as a JPEG type image out of there.
918.26 In reply to 918.25
Michael ,
I just discovered the print screen method a few minutes ago.
I'm more of technician then a graphic artist so I even have to learn the basic stuff .
Here's a jpeg of a basic bassguitar body I'll try to cncrout it in a scaled size version next week .
Paul
a very complet graphic tool (and free) is Artwaever http://www.artweaver.de/ (multi languages)
It's like Toshop + Painter :)
Show messages:  1-7  8-27  28-47  48-50
