Free 3DM importer add-on for Blender
9171.1
I just saw this discussion at the Blender Artists forum, about a free add-on that can import Rhinoceros 3DM files.
https://blenderartists.org/t/import-rhinoceros-3d-files-into-blender/1136070
I'm not sure if it's also fully compatible with MoI 3DM files, but it's definitely interesting.
Regards,
Metin
9171.2 In reply to 9171.1
Hi Metin, it does not appear to be compatible with 3DM files saved from MoI because it only processes display mesh information that Rhino caches in 3DM files and does not read NURBS data directly.
9171.3 In reply to 9171.2
That's a bummer. I've mentioned MoI in the discussion. Hopefully the creator can add MoI 3DM compatibility.
Regards,
Metin
It is not more easy to load the 3D Rhino file inside Moi then export as OBJ ?
And the file OBJ will be surelly better than the transformation by the future Blender Plugin! :)
9171.5 In reply to 9171.4
MoI's mesher is the best, yes. But a dynamic bridge between MoI and Blender would be very nice.
9171.6 In reply to 9171.2
Here's a response from the Blender 3DM add-on developer:
"It currently needs indeed the render meshes (display mesh), but I’ll be using Rhino Compute in the (near-ish) future, so that importing a 3DM without render meshes in the file will use a (local) Rhino instance for the meshing. You could of course also request the Moi 3d developer to save the display meshes as well…"
Regards,
Metin
Message 9171.7 deleted 12 Dec 2018 by BEMFARMER
9171.8 In reply to 9171.6
Hi Metin, that's great that he has already got a solution planned for that!
It doesn't really work for MoI to save display meshes in 3DM files because it greatly increases file sizes. There's also other problems as well, see here for some previous discussion:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5325.5
http://moi3d.com/forum/index.php?webtag=MOI&msg=5875.3
What is "3DM without render meshes in the file will use a (local) Rhino instance for the meshing"
a tranform nurbs surfaces in a mesh ?
My Moi French Site My Gallery
9171.10 In reply to 9171.9
Hi Pilou, it sounds like it will use a locally installed Rhino to make the mesh, communicating with it from within the Blender plug-in. You'll probably get better results just exporting to .obj format out of MoI though rather than using the plug-in.
9171.11 In reply to 9171.10
Got it. Well, it was almost good news. ;-)
Regards,
M7
