Nudge in 3d View ?
9116.1
I assigned the nudge vertically / horizontally script to the arrow keys.
Is there a way to use this command also within the 3D view without having
to move the cursor into an ortho-view ? This would be helpful when working within
the fully expanded 3D view without needing to switch back to the 4-windows view.
9116.2 In reply to 9116.1
Hi Tom, it should be possible to modify the Nudge script so that it always targets the 3D view when in split mode.
There are a few different versions of Nudge though and I'm not sure which one in particular you are using. Can you please post it here and then I can modify it to behave like you want.
9116.3 In reply to 9116.2
As I often work in full 3D view a nudging function which works within the full 3d view would be useful .
The current one I use does only work in the orthogonal views. The movements possible should be
up/down and left/right front view.
9116.4 In reply to 9116.3
Hi Tom, I'm not sure I understand, do you mean when you have a maximized 3D view you want the same movement you get in the Front view?
Does this attached version do what you need?
9116.5 In reply to 9116.4
Thats exactly it, Michael - THANK YOU so much for another little helper
to streamline my workflow even more .-)
