Thanks, Yes, this is what I am doing now- however, the process is slowed down because the cursor keeps picking up the x,y,and z helper lines. Is there a way to turn off the x, y and z helper lines? In this workflow they are only slowing the process down. If I could turn of those helper lines, making the surface normal the only helper line available, it would make it easier and faster to pick out. As you can see any little savings is nice when there are several hundred stones and prongs to do!
Edit: thank you for pointing out the dispersion script, I will see if it can be helpful
